Help tuning spark timing.
Re: RE: Re: Help tuning spark timing.
Messaggioda vitoos » 28/02/2017, 19:47
Feernan ha scritto:
incubo ha scritto:Better 98.
This is the knock sensors}? Immagine
Enviado desde mi Moto G (4) mediante Tapatalk
Yes
Feernan
Auto: Fiat punto 2013 1.4 8v
Re: RE: Re: RE: Re: Help tuning spark timing.
Messaggioda Feernan » 28/02/2017, 19:49
Yes
So. This 2 wires I connect to a jack plug ? Late to amplifier and to a headphones?
Messaggioda incubo » 28/02/2017, 21:02
Yes,after that you will hear the motor.
Remember to install an egt meter!
Messaggioda Tony Evo » 28/02/2017, 22:20
Feernan check the mail
Messaggioda vitoos » 28/02/2017, 22:29
This is the sound of detonations
Feernan
Messaggioda Feernan » 28/02/2017, 22:40
incubo ha scritto:Yes,after that you will hear the motor.
Okay. Im searching egt meter. It costs around 300usd???
Tony Evo ha scritto:Feernan check the mail
I don't have anything. My email is ferfuentealba22@gmail.com
Thanks. This sound I'm going to listen}?
Feernan
Messaggioda Feernan » 01/03/2017, 0:32
incubo ha scritto:Aridaje...
Hi Leonardo. Me again ... jajajajaja I was making a spark table with a base that Antonio sends me and the tjet map. Is this. Remember that is a base. But it's good for start and don't broke }? Immagine
Messaggioda incubo » 01/03/2017, 14:56
Yes but you must absolutely use the knock sensor.
and install an egt.
I will not stop to tell you, until you have done ad post some photos :lol:
Feernan
Messaggioda Feernan » 01/03/2017, 15:17
incubo ha scritto:Yes but you must absolutely use the knock sensor.
and install an egt.
Okay. Im searching a egt meter.. and i buy the amplificar. What headphones recommend me?
Messaggioda incubo » 01/03/2017, 20:06
I've linked a portable amp, but you can also use other types, also by domestic headphones.
You can even use an amp like this
http://m.ebay.com/itm/Sliver-4-Channel- ... nav=SEARCH
I use a cheap version of these. Better to isolate outside noise.
