Help tuning spark timing.
Feernan
Auto: Fiat punto 2013 1.4 8v
Messaggioda Feernan » 28/02/2017, 3:59
Hello guys... After I tell you my history in presentation forum I need specific help.
If someone doesn't know I broke 2 pistons for bad timing tune that was tune for a paid tuner of my city..
My car is a gpunto 1.48v fire.. compression ratio is 8.5:1 and I use 98 Oct shell fuel only. And I boost 1.3 bar max constant 1.26
I wanna know what values are approximately good for my engine as base .. I don't wanna broke again.
I was talking with other 2 tuners here. And one say that in fuel boost (1.26 bar) timing must be around 9 ° and the other say that timing must be approximately 20°...
I'm so lost. I don't have previous experience .
Thanks for help
Enviado desde mi Moto G (4) mediante Tapatalk
rosso alfa
Auto: Gtv V6 TB
Re: Help tuning spark timing.
Messaggioda rosso alfa » 28/02/2017, 11:58
Hi, there is not a specific value for the advance comprared to the compression ratio valid for any engine, it depends on many factors, such as piston bore, shape of the combustion chamber, domes on the piston top, camshaft timing, and the turbocharger you used.
With that 72 mm piston I would stay around 12° in the max torque range, up to 18° after the power peak, clearly with the right AFR (11-11.5)
Feernan
Re: RE: Re: Help tuning spark timing.
Messaggioda Feernan » 28/02/2017, 15:09
rosso alfa ha scritto:Hi, there is not a specific value for the advance comprared to the compression ratio valid for any engine, it depends on many factors, such as piston bore, shape of the combustion chamber, domes on the piston top, camshaft timing, and the turbocharger you used.
Thanks. This is that I wanna know.. a reference.... I have a kkk16 borgwarner turbo with original camshaft.
Messaggioda incubo » 28/02/2017, 17:42
Aridaje...
Messaggioda incubo » 28/02/2017, 17:48
Before doing damage again, starts from this base.
You don't have good cylinder head.
12° in the max torque range is too much in my opinion.
Feernan
Messaggioda Feernan » 28/02/2017, 17:54
incubo ha scritto:Aridaje...
incubo ha scritto:Before doing damage again, starts from this base.
Thanks a lot Leo...
I have a question . What fuel are u running?
Messaggioda incubo » 28/02/2017, 17:57
I use only 100octane but @ 1.3 bar you can use 95.
100 is better ;)
Feernan
Messaggioda Feernan » 28/02/2017, 17:58
incubo ha scritto:I use only 100octane but @ 1.3 bar you can use 95.
100 is better ;)
Here. Only have 95 or 98. I'm running only 98
Messaggioda incubo » 28/02/2017, 18:24
Better 98.
The important thing is that you learn to use headphones and the knock sensor
Feernan
Messaggioda Feernan » 28/02/2017, 19:41
[quote="incubo"]Better 98.
This is the knock sensors}? Immagine
