Introducing me.. Fiat grande punto ms2
Feernan
Auto: Fiat punto 2013 1.4 8v
Re: RE: Re: Introducing me.. Fiat grande punto ms2
Messaggioda Feernan » 26/02/2017, 20:57
incubo ha scritto:Hi Fernando :)
Give us much information as possible.
Also you must learn to use the knock sensor.
You looked for information on how to listen?
Hi Leonardo... I don't learn yet.. but I'm going to learn. What I have to have to listen knocks?
Enviado desde mi Moto G (4) mediante Tapatalk
Messaggioda incubo » 26/02/2017, 21:32
Knok sensor,headphones and an amplifier.
You have to connect the two sensor wires to a jack, such as headphones.
Then you need an amplifier type this http://m.ebay.com/itm/FiiO-A1-Portable- ... nav=SEARCH
where colleagues headphones.
Messaggioda Flycat » 26/02/2017, 21:40
Fernando over 11° advance timing in full boost is too high for all engine! if you use e85 or equal gasoline, you can set near 17°, but with a 98/100 ron, 11° is near to max advance can you use, 10afr is too rich, the engine work good 11.5/12.5afr, when your engine go in boost, the advance timing go to low value, your problem is here!
Messaggioda incubo » 26/02/2017, 21:46
You have an egt meter?
Messaggioda incubo » 26/02/2017, 21:51
Remember that you have to invite everyone to a barbecue... :mrgreen:
Feernan
Messaggioda Feernan » 26/02/2017, 22:34
Alfaservice ha scritto:Hello Mister! .msq attached. It seems several degrees d 'advance. Attach msq we see better.
I can't upload with tapatalk
incubo ha scritto:Attach your msq Fernando.
Still you have an excessive advance... :o
I can't with tapatalk
incubo ha scritto:Knok sensor,headphones and an amplifier.
Okay. Can I use original knock sensor ??
Flycat ha scritto:Fernando over 11° advance timing in full boost is too high for all engine! if you use e85 or equal gasoline, you can set near 17°, but with a 98/100 ron, 11° is near to max advance can you use, 10afr is too rich, the engine work good 11.5/12.5afr, when your engine go in boost, the advance timing go to low value, your problem is here!
Full bost 1.25 bar? I was taking With another tuner and he say that with 8.5 RC the timing in full bost with 1.25 /bar must be about 20... I don't know if he is acerted
incubo ha scritto:You have an egt meter?
No I have only wideband full pressure and boost gauge
incubo ha scritto:Remember that you have to invite everyone to a barbecue... :mrgreen:
Ajjaja yes.
Feernan
Messaggioda Feernan » 26/02/2017, 22:56
There is
Messaggioda incubo » 26/02/2017, 22:59
T-jet 155cv stock
Messaggioda Desmo.3 » 26/02/2017, 23:03
Hi Fernando, you can use your stock knock sensor, it's basically a microphone with which you can hear if you're detonating and it's essential to make a good map. You'll need also an egt sensor, install it before the turbo, in front of the third cylinder that, usually, it's the hotter in an inline 4 engine.
And sry for my english :p
Messaggioda incubo » 26/02/2017, 23:04
This is the spark table of the stock engine. Take it as an example to understand. Your tuner is not very experienced...
My 2 cents
