Help tuning spark timing.
Re: Help tuning spark timing.
Messaggioda Desmo.3 » 01/03/2017, 20:34
Do you have LPG?
Feernan
Auto: Fiat punto 2013 1.4 8v
Re: RE: Re: Help tuning spark timing.
Messaggioda Feernan » 01/03/2017, 22:22
incubo ha scritto:I've linked a portable amp, but you can also use other types, also by domestic headphones.
You can even use an amp like this
http://m.ebay.com/itm/Sliver-4-Channel- ... nav=SEARCH
I use a cheap version of these. Better to isolate outside noise.
Okay. I buy the first. Thanks for ur help
Desmo.3 ha scritto:Do you have LPG?
I dont know what is this?
Enviado desde mi Moto G (4) mediante Tapatalk
Messaggioda incubo » 02/03/2017, 0:12
Try looking on ebay.co.uk for instrumentation,it is less expensive.
Tony has done some tests with various probes, also ask him.
Good night :)
dominic
Messaggioda dominic » 02/03/2017, 11:42
I've found this simple guide to build headphone for listening knocks, if it could be usefull:
Knock Listen Device.pdf
If we don't use the same knock sensor also for the ECU, is it possible to don't use the capacitors to isolate the signal?
So, I think that we could use some classic rubber headset with this above to spend little:
http://www.ebay.it/itm/CUFFIA-ANTIRUMOR ... Swr7ZW3rFb
Messaggioda incubo » 02/03/2017, 11:56
He should not connect it to the ECU but only hear him. He does not need an interface module.
For the headphones i use working headphones with speaker inside.
I used the image as an example.
I prefer big speakers rather than small earbuds.
dominic
Messaggioda dominic » 02/03/2017, 15:21
Yes, he don't need with MS2 to connect the knock sensor to the ECU but that guide could be useful to make a simple and clean connection.
For the headphones your solution is the best, mine is another cheaper one.
Feernan
Messaggioda Feernan » 04/03/2017, 17:45
incubo ha scritto:He should not connect it to the ECU but only hear him. He does not need an interface module.
Leo! how re u? I have a question... The tjet pistons how many pressure or HP support? I have possibility to put forged pistons but it's expensive...
Messaggioda incubo » 04/03/2017, 19:18
I'm fine thanks.
I don't understand why you want to use the t-jet pistons.
They are for a motor 16v and then you have the flare points (those for the valves) where it could remain unburned gasoline.
Why not use the stock?
The t-jet pistons hold much but you do not absolutely have to have detonation.
Feernan
Messaggioda Feernan » 14/03/2017, 22:23
Hello my again. I have a problem. My country have restrictions for imports.. so i have to wait 3 {month the egt gauge...
What can I do ?
Messaggioda Tony Evo » 14/03/2017, 22:30
provisionally you can make a map without EGT, but you'd better be very careful with the map
