incubo ha scritto:Are you using the MS in parallel to the stock ECU?
Just for curiosity...
Yes incubo. Why}? What anothers problems can I have???
Enviado desde mi Moto G (4) mediante Tapatalk
Alfaservice ha scritto:You should make detailed pictures to your controller pcb so you understand what you're using. The petrol pump is ok, the 'injectors for a pressure boost that you're using should be sufficient .At least you can understand whether the unit can use a better firmware
Alfaservice ha scritto:attach a photo with more resolution. To see to understand the hardware configuration. Maybe someone please make the main micro area
nova ha scritto:o.t. what clutch do you use?
