Introducing me.. Fiat grande punto ms2
Feernan
Auto: Fiat punto 2013 1.4 8v
ECU: MS2 V3.57
Re: RE: Re: Introducing me.. Fiat grande punto ms2
Messaggioda Feernan » 27/02/2017, 0:08
incubo ha scritto:Are you using the MS in parallel to the stock ECU?
Just for curiosity...
Yes incubo. Why}? What anothers problems can I have???
Enviado desde mi Moto G (4) mediante Tapatalk
Feernan
ECU: MS2 V3.57
Messaggioda Feernan » 27/02/2017, 0:25
Alfaservice ha scritto:You should make detailed pictures to your controller pcb so you understand what you're using. The petrol pump is ok, the 'injectors for a pressure boost that you're using should be sufficient .At least you can understand whether the unit can use a better firmware
This is.ImmagineImmagineImmagine
Alfaservice
Auto: Alfa 33
Messaggioda Alfaservice » 27/02/2017, 7:26
attach a photo with more resolution. To see to understand the hardware configuration. Maybe someone please make the main micro area
nova
Auto: mx5 1.6 nb
Messaggioda nova » 27/02/2017, 11:02
o.t. what clutch do you use?
Feernan
ECU: MS2 V3.57
Messaggioda Feernan » 27/02/2017, 19:28
Alfaservice ha scritto:attach a photo with more resolution. To see to understand the hardware configuration. Maybe someone please make the main micro area
nova ha scritto:o.t. what clutch do you use?
I'm using sintered clutch with competition diaphragm and 6 pills/pads.
Alfaservice
Auto: Alfa 33
Messaggioda Alfaservice » 27/02/2017, 23:30
Although the pictures are not seen well all components it does not seem all that different from a normal Ms2. The can update with a new firmware msextra.com
Feernan
ECU: MS2 V3.57
Messaggioda Feernan » 28/02/2017, 2:04
Okay. Thanks. What version I have and what's the new firmware.? What changes? Thanks a lot.
Alfaservice
Auto: Alfa 33
Messaggioda Alfaservice » 28/02/2017, 13:14
Yours is a very old version, the new version is much better. Because in time when they realized that some things could be improved have arranged.
